are both ln2 cams the same?(2.2 and 2200)  anyone know?  is there somewhere i could go(like a website or something) that would have their specs?
i looked it up on rockauto.com to see the cross reference.
i looked up a 98 LN2:
part number: CS1567
Mnfr: Sealed Power
BUICK	CENTURY CUSTOM	1994
BUICK	CENTURY SPECIAL	(1994 - 1996)
CHEVROLET	BERETTA	(1994 - 1996)
CHEVROLET	CAVALIER	(1995 - 2002)
CHEVROLET	CAVALIER LS	(1995 - 1998)
CHEVROLET	CAVALIER RS	(1994 - 1998)
CHEVROLET	CAVALIER VL	1994
CHEVROLET	CORSICA	(1994 - 1996)
CHEVROLET	LLV	(1994 - 1995)
CHEVROLET	S10 PICKUP	(1994 - 2002)
GMC	SONOMA	(1994 - 2002)
OLDSMOBILE	CUTLASS CIERA S	1994
OLDSMOBILE	CUTLASS CIERA SL	(1995 - 1996)
PONTIAC	SUNFIRE	(1998 - 2002)
PONTIAC	SUNFIRE SE	(1995 - 1997)
thats everything that cam is supposed to fit in.
1997 Cavalier Z24
Bomz Short Ram Intake
Vibrant Cat-Back
KYB GR2 Struts
Goldline 1.75" Springs
RK Sport Upper Insert
RK Sport Lower Dogbone
Custom Tune by Shane @
innovativetuning@rogers.com
15.647 @ 88.02 MPH
may seem like a dumb question coming, but what is a C/L? I haven't heard that term before. . ..
To the best of my knowledge the '98+ 2200 LN2 cam specs are:
Intake duration @ .050" : 185*
Exhaust duration @ .050" : 185*
Intake lobe lift : ..263"
w/ 1.5 rockers @ the valve : .421"
EXhaust lobe lift : .263"
Intake C/L : 108* ATDC
Lobe Separation Angle : 112*
do u mean 1.6 rockers or 1.5? if 1.5 is correct, how much would lobe lift be with 1.6 rockers?
just multiply the cam lobe lift by 1.6 adn you will have valve lift with the 1.6 rocker
madjack i am taking a 2200 apart within the next few weeks if you pay for shipping ill send you the cam out of it
Is this happening?  I have no interest in the cam, but I am interested in getting the cam sensor angle measurement.  I would be willing to cover shipping to NH in order to make a comparison against a 97 cam.
-->Slow
once i get the engine apart i can send the cam and top end to whoever wants all i am using is the block crank rods and pistons
this thread got pretty interesting...waiting...
MadJack wrote:The '94-'97 2.2L LN2 hydraulic roller cams specs are:
Intake duration @ .050" : 198*
Exhaust duration @ .050" : 198*
Intake lobe lift : .288"
w/ 1.5 rockers @ the valve : .432"
EXhaust lobe lift : .288"
Intake C/L : 109* ATDC
Lobe separation Angle : 114* (some specs from Crane Cams were 113*, others have said 114*)
Note : The '94 & '95 cams don't have the cam position sensor notch that is required for a '96 or '97 motor.
Lobe Separation Angle : 112*(Some specs from Comp Cams said 111*, others have said 112*)
I accredit the differences in the LSA to either cam wear or manufacturing irregularities.
While the position of the crank position sensor notch is different between the 2.2L & 2200s, it isn't certain that the cam notches are different. I too used to believe they were different, but I'm not so sure. I still need to get a 2200 cam to compare the positions. Besides the C/Ls on the 2200 cams would be more useful on a N/A motor, while the 2.2Ls C/Ls would be better suited to boost or nitrous.
 Since the '98-up rockers are actually 1.52:1, shouldn't there be a correction of at-valve lift?
Go beyond the "bolt-on".
Intake duration @ .050" : 198* (should be 188*)
Exhaust duration @ .050" : 198* (should be 188*)
Well, I just got done degreeing the cam, the lobe lift, C/L & LSA are correct, but the duration is wrong, it is only 188*, not 198* as stated above. I ran the measurements and calculations a few times each to be sure. I didn't help, the timing chain was so loose, all my measurements were 4* retarded. Then again this was the original timing set in the motor.
I did make a FUBAR, I forgot to get the angle of the cam position timming notch!
  I did look though and it appears to be about 30 cam degrees after the cam dowel.
Well, that isn't much of a surprise... As you may recall, the LN2 Guide said that the Series-II engine got a cam that in conjunction with the new head made more mid-range power. And from what I remember from reading about the effect C/L & LSA have on engine performance, a tighter LSA cam makes the power-curve more peaky. Combine that with the given fact the factory exhaust manifolds aren't the best in design suited for the flow requirements that the cam necessitates, and it's no-wonder why the the all-stock Series-II LN2 falls on it's face compared to the Series-I in both power & efficiency performance aspects: That damn manifold is robbing us of usable torque!
Guess I'm gonna hafta swap-in a Series-I cam if I want to get the most usable torque outta my Series-II when I install that 22"-runner header. Or when I go with the Tri-Y from
turbos10.com. Is Al's Headers still in business? I dunno...
Hey MadJack, you got one of those "Cam Doctors" that hook-up to a computer to measure cams? Or is the ol' classic method you're using?
GM's published values don't always match actual numbers.  Cams are just one part affected.  The cam specs I've posted were from aftermarket cams, IIRC Clevite branded cams.
-->Slow
Is the 2200 ln2 the non-ecotec engine?
