I am in need of a set of 6 flywheel bolts for a 02 cavalier Z24.
My GM dealer says GM is out of stock/backordered, and they have no idea when they would even come in if i were to special order.
The nearest dealer with any in stock is like 200 miles away.
these are GM part # 22531274
suposedly 10x1x19 are the measurements.
if you work at a dealer, or know where i can get my hands on a set of these let me know. ksoggs@gmail.com
your dealer cant get them in from another dealer???
thats f'd up.
they didnt offer that up....
just said "no local dealers have them"
i asked "well how far is the closest "not local" dealer... and he said "new york, almost 200 miles away."
"and it looks like GM warehouses are out of stock, probably backordered, so i have no idea when i could even get any, sorry"
Stop @ Summit and pickup ARP Part # 039254-2801. They are for a Ford Modular 4.6/5.4 flywheel, but they work fine on the LD9
Pressure Plate bolts are part # 108-2201
Jason
99 Z24 Supercharged
157hp/171tq - NA
190hp/170tq @ 6psi
LD9 for Life
There must be a shortage because platinum prices have gone up so high, oh wait I forgot, those bolts sell for their weight in gold
___________________________________________________________________
Mitsu TD06-20g |3" Turbo-back Exhaust | 61mm Bored TB |
HP Tuners | Innovate WB02 | Spec Stage 3 | Team Green LSD | TurboTech Upper | Full Addco Sways | Sportlines & Yellows |
Blwn LD9 wrote:Stop @ Summit and pickup ARP Part # 039254-2801. They are for a Ford Modular 4.6/5.4 flywheel, but they work fine on the LD9
that number turns up blank on summit... are these the ones?
http://store.summitracing.com/partdetail.asp?part=ARP%2D151%2D2801&autoview=sku
I also found out that my gm dealer is an asshat and the part number he gave me was for an automatic.... not a 5-speed.
the manual part number is 22531273. the 4 is for an auto....
anyone know the thread and size of the manuals bolts? i imagine the threads are the same... maybe just a different head on it?
will those ARP bolts work without modification? and did you use them on a manual or auto?
I will double check the part number when I get home, but I think the Summit link is right
The ARP bolts work on my 5spd without any modification
Jason
99 Z24 Supercharged
157hp/171tq - NA
190hp/170tq @ 6psi
LD9 for Life
ARP Part # 254-2801 is what I used. Your link is the same bolt just cheaper and the right quantity
Jason
99 Z24 Supercharged
157hp/171tq - NA
190hp/170tq @ 6psi
LD9 for Life
my dealer can get them. i get a decent price. PM me if you'd like a set.
