I broke something...need some help - Performance Forum
Friday, June 13, 2008 10:13 PM
after removing my old header i notice that one of the metal lines on the steering rack has been rubbed right through by the header. it connects to a plastic ring on pass side rack and i cant see where it goes to on the drivers side. its not threaded so im sure it doesnt hold pressure, but i have no clue what its for???? i would like to take care of it before i put the new header in. any help is appreciated.
Re: I broke something...need some help
Monday, June 16, 2008 6:22 PM
If your brakes don't go out (Hey, I don't know how they run those lines on a J-bod so I can't say) Then it's for the low-pressure PS fluid return (Most likely).
Go beyond the "bolt-on".
Monday, June 16, 2008 6:33 PM
Pretty sure you-re talking about the crossover tube that equalizes pressure in the bellows boots, it should connect from one boot to the other.
Monday, June 16, 2008 8:08 PM
yup sounds right on the money cavmania
Tuesday, June 17, 2008 5:16 AM
thanks guys. made a patch for now. im sure this tube only comes with the rack assembly.
Tuesday, June 17, 2008 5:59 AM
cavmania wrote:Pretty sure you-re talking about the crossover tube that equalizes pressure in the bellows boots, it should connect from one boot to the other.
exactly....it would be REAL messy if it was a fluid line.
