parts from the 2.3 - Performance Forum
parts from the 2.3
Tuesday, January 01, 2008 1:21 PM
what parts can you take from the 2.3/other motors(if any) and fit them on to the 2.4 besides the cams....cause i need a new throttle body and i want a high output one....can i get this off a 2.3....oh and how hard is it to put on a new throttle body....considering all i'v done is a few oil changes and put on my WAI?....
Thanks chris
2000 z24 Cavalier
Re: parts from the 2.3
Tuesday, January 01, 2008 2:05 PM
Pretty much everything from the 2.3L Quad4 can be adapted to the LD9 except the crank. And there really is no such thing as a "HO" throttle body. All 2.3L Quad4 engines come with a 56mm TB.
Tuesday, January 01, 2008 3:52 PM
x2 ..just about everything is swappable...parts wise..some need more modification than others ...the crank wont fit at all ...but anything else is has potential
Wednesday, January 02, 2008 7:47 AM
cool soo if i get the 56mm tb from the 2.3L will i need the intake manafold? ....oh and will this give me much power....or should i just get ahold of a stock one?
2000 z24 Cavalier
Wednesday, January 02, 2008 8:34 AM
much power? doubt it..would be nice if you dynoed it though so everyone would know for sure .. itll bolt to your manifold as far as i know..however i would get the throttle bracket that comes with the 2.3 tb
Wednesday, January 02, 2008 8:49 AM
Cool thanks man!!!
2000 z24 Cavalier
Wednesday, January 02, 2008 8:55 AM
The quad4 TB uses 2 larger bolts to mount to the manifold, while the LD9 uses 4 smaller ones, but the TB holes do line up with the LD9 manifold holes. So, you could always drill one or both of the other holes to use all 4 bolt holes if you wanted too.
Wednesday, January 02, 2008 3:07 PM
my friend has an ld9 and if you swap the cams does it do much or is it more for like future proofing?
Friday, January 04, 2008 1:05 PM
apparently swapping the cams give you an extra 10-20 hp depending on yer other mods....
I'm planing on doing them when i get the money
2000 z24 Cavalier
Friday, January 04, 2008 4:24 PM
I just did the 2.3 cams/ "secret" cam swap and did a short write up on it, with a review, list of parts, and short overview of the work required. I just haven't posted it up on here (JBO) yet. If ya'll want I can but my opinion is there is more upper rpm power (not 10-20) and a very slight drop off in torque, un-noticable almost difference. Just let me know, I can post it here or give the link to where it is posted.
Tuesday, January 15, 2008 3:29 PM
yea man i read that thanks for the info man!!
2000 z24 Cavalier
