i am in way of port and polishing my head 1mm oversized valves with a three angle valve job brass valve guides,secret cam swap,2.3 springs and retainers,cometic head gasket, arp head studs,rsm 62mm tb,light weight crank pulley, light weight alt pulley,spec atage 2 clutch and light weight flywheel,ttr uper engine mount,prothane tranmission mounts, venom fuel rail and accel afpr, now the question do you guys think that he stock injectors will be good for this build? with being hpt after.. and in a few months i will be going supercharged...
http://www.cardomain.com/ride/2623318
once you go boosted you will need bigger injectors, but dont install them until you can tune for them. the venom rail is a complete waste.
Yes until you are boosted.
