I have a 2002 LS Sport Sedan with a 2200 2.2L engine. I just bought this car in August and I want more power. I started off with the basics, I had a new header put on, high flow cat, and 2.25" cat back exhaust system (all done by a custom shop locally). I installed an AEM cai. This alone has given me noticeable improvement in power.
My problem is that I don't have the mechanical confidence to do much else by myself. Because of that I've been limited to bolt on horsepower which is why I just bought a JET Power Control Module (very little gain in power).
The other thing is that there aren't many performance parts for the 2200 2.2L... I notice there are alot more parts available for the ecotech motor.
Short of doing an engine swap, I'd like some advice from other 2200 owners. I'd like to know what else I can do to get more power.
Things I'd like to investigate improving:
Throttle Body
Spark plugs and new wires (not sure how much this will improve anything, but I'm very confident I can do this mod)
Upper and lower motor mount
Strut bar (very confident in doing this mod, but more of a handling mod rather than power)
Other than that, I don't know what else I can do to improve performance.
I've got several grand I can blow, and could just go somewhere and have it done, but I'd like the satisfaction of doing it myself.
So have at it guys, unload your advice.
56MM HO throttlebody will help, thats almost bolt-on.
porting/polishing the head will get you some more power.
1.6:1 roller rockers.
Or if youve got a few grand why not go turbo? itll only be a few grand if you piece it together, and itll be the most power you can get.
You could also do nitruos oxide.
A cam is an option, but if youre not very mechanically inclined it might be more $$ to get and get installed than its actually worth.
Theres a few things you can do, and make some respectable power.
The JET module youve got...I dont know what it does, or what its supposed to do, but i assume its trash, as theres no "chip" for our 3rd gens
that does nothing. just a waste. there is always HPtuner software thats the closet thing to chips
