Question on Wiring for Hahn SII Inline Fuel Pump Relay - Performance Forum
Sunday, June 17, 2007 7:09 PM
Ok here we go, in the diagram in the instruction manual, it shows the two main posts for the power to the fuel pump, it also shows a ground, and also the signal wire for the relay. But you can clearly see there is only 3 posts on this relay, so is it fair to assume the 'green wire' is the signal wire and the relay grounds through the frame mount? Does anyone know first hand, I have been unable to find anymore specifics on this particular relay and I dont want to go frying anything tomorrow when I hook it up.
Any help is much appreciated.
___________________________________________________________________
Re: Question on Wiring for Hahn SII Inline Fuel Pump Relay
Sunday, June 17, 2007 7:52 PM
Ummm...that piece definately isn't from an HRC kit.
5K PB: 24:50
10K PB: 54:26
Sunday, June 17, 2007 7:59 PM
Wonderful, it came with a used HRC kit, here is a pic of the fuel pump, I think its the same bracket maybe you could clue me in there.
Monday, June 18, 2007 10:04 AM
BlackEco wrote:Wonderful, it came with a used HRC kit, here is a pic of the fuel pump, I think its the same bracket maybe you could clue me in there.
That pump and bracket are correct for the kit.
5K PB: 24:50
10K PB: 54:26
Monday, June 18, 2007 12:29 PM
Thanks!
