I've searched and could only find info on the eco and I need it for the 2.4. I am in the middle of my rebuild on my LD9 and my wiseco pistons are .020 overbore and the ring gaps are not what they should be according to the instructions. I called Wiseco and they reccomended the standard .004 per inch of bore so that would give me .01425 for the top and second rings correct? The top rings all have .020 gap and the second rings have .012 gap. The rep from Wiseco said .004 is good for anything under 20 psi of boost and I should gap up to .006 per inch for over 20 psi. The top ring is already at .006 without me touching it so my question is, should I do the same to the second rings? I wasn't planning on boosting over 20 psi so idk? What do you guys with boosted 2.4's have your rings gapped to?
nobody gapped their own rings???
