Different options on performance??? - Performance Forum
Tuesday, January 16, 2007 9:01 PM
I have an 03 Cavlier 2.2. I dont have enough right now to buy a turbo kit or the supercharger kit. Are there any other engine modifications that are possible. I already have the usual K&N short ram intake on.
"You can only feed them semen for so long before their legs fall off."
Re: Different options on performance???
Tuesday, January 16, 2007 9:25 PM
you dont look much do you?? Performance FAQ found at the top of this very forum
but you are only limited by the size of your wallet and the willing to learn
Is not knowing enough the only thing setting you back from the turbo or super? Or are you also limited by funds? The reason I ask, is because if you want NA mods, it typically ends up as a waste of money (especcially if you decide to turbocharge). The typical NA mods are:
-header (waste if you decide to turbocharge)
-complete 2.25" exhaust ...(waste if you decide to turbocharge)
-Cams ...(waste if you decide to turbo or supercharge)
-patriot stage 2 head ...(I suspect you won't be getting this anytime soon, but it is available)
-High compression pistons ...(waste if you decide to turbo or supercharge)
-Balance shaft neutralization
-Lightweigt flywheel (if you have a manual)
I'm sure there is more I am leaving out, but those are the essentials that will net more Naturally Aspirated power.
Wednesday, January 17, 2007 12:32 PM
Or you can just put her on the bottle... that always works =)... hehehehe....
http://www.motortopia.com/cavyfreak442/cars
Best ET to Date: 14.251 @ 98.51 mph. 13's or Bust Baby!
