95 2.2L ecu pinout - Performance Forum
95 2.2L ecu pinout
Friday, December 15, 2006 9:36 PM
looking for a 1995 fire/cavi ecu diagram or pinout for the ecu to do a safc controller
thanks in advance!!!
jason
Re: 95 2.2L ecu pinout
Friday, December 15, 2006 10:35 PM
with what engine
Friday, December 15, 2006 11:04 PM
what ones do you need ??
Saturday, December 16, 2006 9:27 PM
as the title says 1995 2.2l, i am hooking up a safc controller
thanks
jason
Saturday, December 16, 2006 10:22 PM
CONNECTOR JI GREY 32 PIN
J1-1-
J1-2-INJ DRIVER 1 & 4
J1-3-
J1-4-INJ DRIVER 2 & 3
J1-5-
J1-6-O2 SENSOR LOW
J1-7-
J1-8-
J1-9-ECT SENSOR SIGNAL
J1-10-IAT SENSOR SIGNAL
J1-11-BATT FEED
J1-12-O2 SENSOR SIGNAL
J1-13-CKP GROUND
J1-14-CKP SENSOR FEED (B+)
J1-15-IAC "B" LOW
J1-16-IAC "B" HIGH
J1-17-7X SIGNAL
J1-18-
J1-19-IGN CONTROL "A"
J1-20-
J1-21-IGN CONTROL "B"
J1-22-
J1-23-PCM GROUND
J1-24-PCM GROUND
J1-25-CRUISE ENGAGE
J1-26-COOLANT LEVEL SIGNAL
J1-27-OIL LEVEL SIGNAL
J1-28-FIELD CIRCUIT
J1-29-TP SENSOR SIGNAL
J1-30-A/C PRESS SENSOR SIGNAL
J1-31-IAC "A" HIGH
J1-32-IAC "A" LOW
BLUE 32 PIN (J2)
J2-1-FUEL PUMP RELAY CONTROL
J2-2-KNOCK SENSOR SIGNAL
J2-3-MAP SENSOR SIGNAL
J2-4-IGN FEED
J2-5-
J2-6-MAP, ECT, A/C SENSOR GRD
J2-7-5V REF
J2-8-VSS OUTPUT
J2-9-IGN FEED
J2-10-A/C COMP RELAY CONTROL
J2-11-CRUISE DISABLE
J2-12-COOLING FAN RELAY CONTROL
J2-13-MIL CONTROL
J2-14-EGR CONTROL
J2-15-TCC CONTROL
J2-16-EVAP CANISTER PURGE CONTROL
J2-17-
J2-18-VSS SIGNAL HIGH
J2-19-
J2-20-SERIAL DATA
J2-21-VSS SIGNAL LOW
J2-22-TP, IAT,SENSOR GRD
J2-23-5V REF
J2-24-LAMP CIRCUIT
J2-25-PCM GRD
J2-26-OIL PRESS SWITCH
J2-27-
J2-28-
J2-29-PRNDL"A"
J2-30-PRNDL"B"
J2-31-PRNDL"C"
J2-32-PRNDL"P"
Sunday, December 17, 2006 4:32 PM
95 2.2 ecu are the same as the 95 2.3l manual if that can help!!
