Putting the B&M short throw shifter into the 05, and just have one question.
I have put one in the 01 Z-24 I had previously, and had one problem that I would like to avoid this time.
At the end of the shifter cables are plastic rectangular box connectors that connect the shifter to the cables. One of them cracked when I opened them on the 01.
I would like to know if there is a trick to opening those connectors without breaking them????
Thanks for the help!
cya
'05 LS Sport.....I miss my Z
The trick is to be very careful and to know when they are open and not try to force them further.
When the cover pops up about 1/4" or so, the rod will be free. That's all you need to do. Don't try to pop the cover up 90 degrees or anything.
Thanks Wild Weasel
I will be careful not to force them open too far.
cya
