2.4l TB swappable to 2200? - Performance Forum
Wednesday, March 08, 2006 8:31 PM
Is it possible to put a 2.4's throttle body on the 2200? Im going off of pics, but it looks like it has the same bolt pattern. Just wondering, a guy I know just did the eco swap and doesn't need the 2.4's anymore. I know the extra 4mm's won't do much, but for free it can't hurt.
Failure is not failure if you learn from it
Re: 2.4l TB swappable to 2200?
Wednesday, March 08, 2006 8:33 PM
yes I'm sure they swap over. me and a friend checked it when I took off my tb.
Lee
JDM Civic Hatch
Wednesday, March 08, 2006 8:42 PM
2.4l tb is the same size as the 2200 and will swap over
both are 52mm
the 2.3 l tb is what your looking for..its 56mm
Wednesday, March 08, 2006 9:02 PM
Oh, my bad, I thought the 2.4 was a 52mm and the 2200 ws a 48mm. IDK, I never actually mic'd them. Thanx, does anybody know where to get the HO TB, besides the junkyard. All the yards around here don't have any 2.3's except the LO, and I know the bolt pattern is different.
Wednesday, March 08, 2006 9:12 PM
dude the LO and the HO throttle bodies are the same thing... 56mm. the intake manifolds were different, not the throttle bodies.
Wednesday, March 08, 2006 9:17 PM
the throttle body will still work, or at least should. many people use it..it doesn't have to be the lo
Wednesday, March 08, 2006 9:32 PM
I went to the yard and looked at the LO's TB, and it only had 3 bolts holding it down. this was also on a grand am 2.3L, if that makes a difference.
Wednesday, March 08, 2006 9:35 PM
yeah i do beleive that 2 of the bolts line up with the 2200 mani, and it will still seal correctly...
i think its in the faq some where, but i know people are running that TB
Thursday, March 09, 2006 6:22 PM
mine works just fine on my 2.4 and the same one worked just fine on my 2200
