air intake on ebay - Performance Forum
air intake on ebay
Tuesday, December 06, 2005 8:02 AM
Re: air intake on ebay
Tuesday, December 06, 2005 8:09 AM
And intake is an intake, is an intake. Its fine as long as you have the 2200 engine and you still have the box that says 2200 on it.
Tuesday, December 06, 2005 11:53 AM
Judging by what that intake pictured looks like... it won't make it much past your valve cover. Look. Go to http://www.ny-jbodies.org/library/engine/2200/homemadeintake.htm to learn about the homemade CAI you can build.
Tuesday, December 06, 2005 11:57 AM
no it works pefectly just you have to remove your airbox. like they said above an Intake is an Intake. No need to pay 200 dollars for the same piece of aluminum just with decaling on it. Theywork fine as long as you remove your stock airbox your hood will close.
Tuesday, December 06, 2005 12:06 PM
Well I understand that. I'm talking about the length of pipe after the bend. It looks like the filter would be almost right next to the head and not much closer to your battery.
Tuesday, December 06, 2005 12:17 PM
just save your cash, they dont do much
Tuesday, December 06, 2005 1:02 PM
Shaune Drake wrote:just save your cash, they dont do much
got proof?
Tuesday, December 06, 2005 1:04 PM
Only problem with that DIY, if you have the 2200 your TB is sunk about 6"s behind the engine, its not on top.
Tuesday, December 06, 2005 1:34 PM
El Fuego ( the unstable ) wrote:Only problem with that DIY, if you have the 2200 your TB is sunk about 6"s behind the engine, its not on top.
Ny-Jbody.org wrote:Parts needed:
1- 92-2000 Honda Civic intake
1- 94-2001 Honda Prelude Intake
1- 3 inch 90 degree rubber elbow
(if you own a 95-97 2.2 you will
need a 45 degree elbow instead) 1- 3 inch cone filter
1- PCV breather filter
2- 3 inch hose clamps
It's right there dood. Different elbows for the different motors.
Tuesday, December 06, 2005 2:19 PM
I had a 90 degree elbow connected to a 4" riser. So its still wrong.
