I am going to order a Borla Pro XS muffler. What dimensions do I need to get?
center in center out???
This is going on a stock 05 Cav, for now.
I believe they only come in one size. I would get the 2" center in/center out muffler since its going onto your stock exhaust.
Cracker Rocket wrote:I believe they only come in one size. I would get the 2" center in/center out muffler since its going onto your stock exhaust.
Actually, it doesn't really matter what inlet size you get, as long as you have a good welder install it.
Most aftermarket companies don't make a 2" inlet muffler...I'm not sure if Borla does or not. Go for a 2 1/4" inlet and whatever outlet you want (assuming it comes with a tip) and call it a day.
as long as it isn't smaller than the rest of your exhaust. Ideally you should do 2.25 header-back. In which case you should have a 2.25" muffler inlet.
