are there any such as secret performance cams for the 2200 non-eco?
The whole "secret" cam thing was directed torwards the 2.4 Motors because you could use camshafts from the 2.3 motors and gain power from it...it was a secret at one time.
As far your motor, remember, you only have 1 camshaft which is underneath your cylinder unlike the 2.4, 2.3 & ECO motors which are over the cylinder head (hence Dual Over Head Cams - Two Camshafts Over the Head). So in order to swap out your cam, you would need to remove your head.
Now, knowing the 2200s and friends with 2200s, in order to gain power from a camshaft swap, you really need to work your head. By just upgrading your camshaft, you're not doing much there because the real restrictive part comes from your cylinder head....if you work the head, you'll unlock a very good amount of power.
Now if you're looking for a camshaft, go to Jbody Performance (
www.jbodyperformance.com), they make one for the 2200 LN2 motor.
Here is a direct link to the page:
JBP 2200 LN2 Camshaft
Good luck.
there is alot of confustion on this topic
let me clear it up for you
on newyorkjbodies website there is this thing about the 2200 secret cam swap
they are wrong, it doesn't exist!
by the way the topic is wrong on here 2200 has only one cam
u may get cams from jbodyperformance.com
Sorry...
You have been banned from posting on this site as of 2005-09-21
00:33:32. This ban will expire 2005-09-28 00:33:32 Pacific Time.
Reason: Comments over the top regarding Jordan Kruger and other members in Versus. Also, if you have a problem with a member e-mailing you, do not bring it into the forums.
If you believe this to be in error, please contact us.
the JBP Stage 2 cam rules!
Send a cam into Comp, Crane, or some other company
Their techs will be able to help you get a custom grind for what you are doing
Plus it's cheaper than JBP
................Which car will hit 400 whp first???................
wrong.. the price that you pay for JBP is worth it. they cater to our cars and know them inside out. So many people have them from here and by promoting them, we can get more stuff for our cars.. get the JBP stage twos'.
NJHK (Sexual Chocolate) wrote:So in order to swap out your cam, you would need to remove your head.
...If you want to do even more work.
Pull the whole engine out,
take off the valve cover,
use magnets to hold lifters up,
pull out cam through side of block (careful, don't scratch up the bearings around it!)
put in new cam
replace timing chain and tensioner at least
put motor back in
If you have semi-decent milage on your engine, then you should probably replace the lifters as well, which means you would have to pull of the head, and therefore also replace just about every gasket on the top end along with your coolant. And hey, since the head is off, maybe you should give it a little port work to make use of that extra cam...
<img src=http://hometown.aol.com/yogiandbooboo7/images/french.jpg>
OHV notec wrote:NJHK (Sexual Chocolate) wrote:So in order to swap out your cam, you would need to remove your head.
put in new cam
put motor back in
he speaks truth
Sorry...
Which cam would you get from JBP for boost setup? Forced Induction or stage 2 or 3?
Scott Kostura wrote:Which cam would you get from JBP for boost setup? Forced Induction or stage 2 or 3?
Well, first I would like to thank you for using the search function rather than posting a new thread.
Could you tell us more about your setup? Other motor work? turbo size? hp goal?
Also, paying JBP's price is rediculous, just have Crane regrind it (same thing JBP does, just much cheaper)
fortune cookie say:
Hey not a problem I try to search first sometimes i can't ever find what i'm looking for. Turbo setup with a FMIC, Forged pistons and rods new performance cams( what i'm looking for at the moment), I want to buy the Performance head from hypsy he was talking about one that has upgraded valvetrain except for the valves, 16G turbo off of the EVO 3. Looking to run mid to low 13's but will settle for low 14's, lol. If anybody has any parts please speak up thanks. O yea 2200 motor sorry almost forgot that thanks for any help.
Oh and Mad Jack i'm not good with the technical terms and stuff can u put it in short idiot version not being a Dick thanks
Well, you didn't really give us any information there
, just that you're running a big-wheel 16G. Compression ratio, how much boost, horsepower goal, powerband?
The head from Hypsy does not have an upgraded valvetrain for the 2200, only for the DOHC motors.
fortune cookie say:
Well, you didn't really give us any information there , just that you're running a big-wheel 16G. Compression ratio, how much boost, horsepower goal, powerband?
Stock compression or whatever it is 9:, looking to run 14 psi or so. I'm sorry to sound like a newbe but what is powerband lol. Oh i was un aware. Where can i get upgraded valvetrain parts?
here is a website you can use:
J-Body Tech Articles
<a href = 'http://ivpnewmedia.com/10thst/tifts/'>
<img src = 'http://ivpnewmedia.com/10thst/tifts/dpBanner.gif'></a>
Not to thread jack, but is there a general rule of thumb for n/a versus forced induction for intake/exhaust degree? Looks like their stage 1 & 2 both have higher degree than the f.i. cam for the same valve lift.
So? Do I go with the one from JBP or get it regrounded by Comp? I need to know exaclty what to do i'm not to sure on cam knowledge
Admiral558 wrote:Not to thread jack, but is there a general rule of thumb for n/a versus forced induction for intake/exhaust degree? Looks like their stage 1 & 2 both have higher degree than the f.i. cam for the same valve lift.
People generally prefer a lower duration for turbo motors because there is pressure in the exhaust manifold which can go back through the cylinder into the intake manifold during overlap.
Scott Kostura wrote:So? Do I go with the one from JBP or get it regrounded by Comp? I need to know exaclty what to do i'm not to sure on cam knowledge
I would HIGHLY suggest reading up on cam basics at least so that you can make a semi-informed decision, there are TONS of articles out there on the intraweb. Your powerband is 95% determined by your cam profile, it is where your hp and torque lies RPM-wise.
fortune cookie say:
ok thanks i'll try to learn cams in a day or to bc i'm waiting on this to complete my bottom end.
Don't rush it...better a delay than a disaster.
I'm almost to 4 years now for my bottom end.
fortune cookie say:
Scott Kostura wrote:Where can i get upgraded valvetrain parts?
Missed this one...you can get stainless valves from carcustoms.net, and custom-length uber-strength pushrods from Crane, or stock length uber-rods from Howell. As far as springs...you're SOL unless you are willing to pay for some fairly heavy machining to adapt longer springs. Check Jack's rocker thread for information on roller rockers, although the stockers should be fine if you go with an aftermarket cam grind.
fortune cookie say:
