2.3 ho t/b onto gm charger - Performance Forum
Friday, September 23, 2005 10:45 AM
well, i finally picked one up today. it came off a 93 grand am gt. so my q is, what exactly do i have to do to install this? ive heard you have to drill the stock manifold[charger] for the 13 mm bolts, and ive heard that you just have to make sure the t/b is centered and use the stock bolts. which one? and also, can i just use the stuff off the stcok t/b and put it on the 2.3 t/b? or will i have to get new parts? and this one came with cruise, but its diff than the 2.4 t/b, can i still use it? if not no biggie. and which ports are which on the 2.3? if you need a pic i can get one lol. thanks again guys.....
2000 Camaro V6.
Re: 2.3 ho t/b onto gm charger
Friday, September 23, 2005 12:14 PM
bah, i wanna get this done today. so my final q is can i just use the 2.4 bolts and make sure that the 2.3 tb is centered? i found everything else
2000 Camaro V6.
Friday, September 23, 2005 12:21 PM
Just center it, I would never drill into charger for this mod!
You must use the 2.3l IAC and I don't think any other 2.4l sensor works with it.
I gotta question though, where the IAC bolts on and the brake booster tube comes off of, is that plate removeable from your TB itself?
Friday, September 23, 2005 12:29 PM
ok, got some pics for ya cause i dont what is what on this lol
^^^^ how does the cruise work on this? or can i not have it? lol
2000 Camaro V6.
Friday, September 23, 2005 12:30 PM
whoops, little big. sorry lol
2000 Camaro V6.
Friday, September 23, 2005 1:28 PM
Figure that ish out man so we'll have something to do later ha
Friday, September 23, 2005 2:04 PM
yes cruice will work with that tb , but you need the bracket for it also
the angles for the cables are different
and ill be the first to say that tb looks like ass , you must live in a area that snows alot , and they salt the roads
and you will need a 2.3 IAC for that tb
Friday, September 23, 2005 10:34 PM
well i cleaned it up ALOT, engine degreaser does wonders lol. and the 2.3 iac, is that the big round hole? cause i broke something on the 2.4 t/b and now it idles at 1.3k and i thought that was the iac. its got kinda of a ('.') plug on it lol. what is the round thing with the orange o-ring on it? is that the tps? i will have to go back sunday and get the stuff. will an iac off a non-ho 2.3 work as well? or do i have to use the ho 2.3 iac? thanks man
2000 Camaro V6.
Friday, September 23, 2005 11:36 PM
the big round thing is where the TPS goes yes,
and if my memory is correct there were 3 styles of TB's all were 56mm and I think work with the same TPS but if you're still not sure, try finding a similar TB.
Tuesday, September 27, 2005 8:19 PM
alright, now i wanna know why only 2 holes are used? wtf? do i have the wrong t/b?
2000 Camaro V6.
