Exhaust wrap on Cat? - Performance Forum
Monday, September 12, 2005 2:31 PM
Can you put exhaust wrap on a catalytic converter? Mine is hitting the heat shield at times and i wanted to stop the noise. Can I do this, or does the cat need to be able to dissipate heat through the body?
Re: Exhaust wrap on Cat?
Monday, September 12, 2005 3:47 PM
wouldnt do it... take it to a shop have em spot weld the sheild...
Monday, September 12, 2005 4:01 PM
If you want to keep your exhaust from moving, get some motor mounts because when your shifting hard your motor will jerk hard and it's probably hitting it that way.
Monday, September 12, 2005 4:06 PM
Cats like heat. So I would say go for it.
My Car
Monday, September 12, 2005 4:12 PM
NJHK (Sexual Chocolate) wrote:If you want to keep your exhaust from moving, get some motor mounts because when your shifting hard your motor will jerk hard and it's probably hitting it that way.
got em already. my cat is just too close to the heat shield. i tried bending the heat shield a bit and it seems to have helped, but time will tell.
Monday, September 12, 2005 5:17 PM
Don't do it. Overheating a cat is a guaranteed way to kill it. Thats why using wrap on a street car header is bad.
Monday, September 12, 2005 5:18 PM
that's what i thought, but i thought I'd ask on the outside chance I was wrong.
Monday, September 12, 2005 5:27 PM
James Cahill wrote:Don't do it. Overheating a cat is a guaranteed way to kill it. Thats why using wrap on a street car header is bad.
The way you overheat a cat and melt it, is by running way rich.
And you don't run header wrap on a header because moisture gets between the wrap and header and corrodes the header.
My Car
Tuesday, September 13, 2005 1:58 PM
Well, I could try to stop the flow of misinformation here, but I won't. I just hope anyone reading this is able to do their own research and find the correct answer.
Tuesday, September 13, 2005 2:33 PM
James Cahill wrote:Well, I could try to stop the flow of misinformation here, but I won't. I just hope anyone reading this is able to do their own research and find the correct answer.
That was why I posted it here though---to get the right answer. Please fill me in.
