Well, sat here and read about 50 posts on this subject and seemed my car could have any one of the problems. The only thing was, almost all the post were for 2.4s or 2200s.
So, I just changed the 02 and plugs in the car due to the 02 being bad. Figure the plugs wouldn't hurt since I had a misfire in #4 when I scanned it in.
Now, at idle the engine pops every 4 or 5 seconds. Like vrrrrrrrr...pop...vrrrrrrr...pop, pop......vrrrrrr, etc.
Also, at about 4000 rpm, the car will hesitate like it's missing or running out of gas. It recovers and then you can go again, but it hesitates for like 3 or 4 seconds.
Under light load, seems all is fine with the exception of the bad idle. I can pull out normal and shift at 3000 rpm or so and not notice a thing. This started about a week ago and that is why I replaced the 02 and plugs. The 02 was bad so I thought that was the problem??
Any thoughts?
Check engine light on?
I root for the underdog...figured I might as well be one
you didnt use BOSCH o2 sensor did you??????
FACT : Statistics show that you are more likely to to be hit by lightning than to die street racing.
FACT : It is our American RIGHT to own a GUN but not to drive a car.
"Those who would sacrifice freedom for saftey deserves neither Freedom nor safety!" - Benjamin Franklin
"The real destroyer of liberties is he who spreads among them bounties, donations and benefits." -- Plutarch
Check engine light is not on...no codes either when I scan it?
Yes, I used a Bosch 02 sensor...OEM part...bad choice?
BAD choice! take it out...throw it away....get an AC DELCO 02 sensor..stick it in there and all your problems should go away
......your not the first to have this happen
scott trent wrote:BAD choice! take it out...throw it away....get an AC DELCO 02 sensor..stick it in there and all your problems should go away
You think? Not sure it would but I can try it I guess. It was doing this a little bit before I swapped in a new 02 and plugs so I was thinking something else might be wrong.
I'll take a look tomorrow at the parts store see how long to get an AC Delco 02 here.
Anyone else?
i say its a bad choice because not only do i speak from experience ..this MAY not be your problem...but everyone i know has had problems with bosch sensors....read the following as proof...
http://www.j-body.org/forums/read.php?f=11&i=97522&t=97522
fuel filter....whens the last time you changed it? if you are having a fuel starvation problem,likely not see a code.
mecp certified installer#39272
^^ also a likley suspect
What it sounds like is your fuel pump is starting to die.
Tach Out Motorsports
Option D Inc.
