fuel pump relay - Maintenance and Repair Forum
fuel pump relay
Wednesday, August 24, 2005 1:19 PM
my fuel pump relay is blowing.......please help me!!!!!!!!!!!!11
Re: fuel pump relay
Thursday, August 25, 2005 4:34 AM
How is the relay "Blowing".
Fuses "Blow" but relays usually have some sort of operating coil failure and will not change state or the contacts fail to make "contact" when the relay is energised.
Did you mean your Fuel pump fuse is blowing?, which, if the wiring is not shorted , usually means a new fuel pump is needed.
Please give more info so someone can help you out.
Alont
