Does anybody know how to do a lubrication of chassis? my 1999 cavalier user manual says it is necessary to lubricate the chassis periodiclly, and shift linkage(A/T&M/T), steering, and suspention are the componnent shold be lubricated. the problem is how to lubricate them? there are these componnents located? another question is where can I buy a air intake sensor?thx!
the only place that u should lube or grease is the tie rod ends....which are obviously on the end of the rack which connects to the steering knuckle behind the tire.....there is a grease fitting on the top of it thats the only 2 grease fittings on cavs and sunfires......as far as the greasing the parking brake cable and shift linkages.....use some white lithium grease and just rub it on the cables and put it on the moving joints where bushings and moving parts are....
I AM the man from Nantucket
