Ive been at this thing for a while, got all the bolts out except one. The pan is loose, but theres a bolt in the back on the driver side where there is a spacer of some sort directly underneath that bolt. I tried a swivel, and cannot get anything on it. Directly next to the flywheel.
The bolt that goes horizontally holding the bottom of the pan on, whatever encloses that bolt spins freely, like a sleeve or something but i cannot get above that with a 3/8 socket wrench. I believe its a 13mm bolt.
Any help would be astounding, thanks!!
sorry i couldnt answer you earlier, man.
idk how far you've gotten but there is a stud right there. you need to take that out, THEN you can remove the aluminum spacer.
RIP silver car. You will be missed.
Thanks man, Im sure thats what it is. I'll just double nut it and get it out. Or weld a nut on.
It already has a nut on the end of the stud it is 7 mm.
