i dont know if this should be here or audio/electronics be cause it seems like a maintenance issue but could also be and electrical issue.
the problem im having is my passenger headlight isnt working, its get a little bright like its getting power but isnt gettin any brighter than a cigarette cherry, and my high beams are on all the time now like the DRLs are on not as bright as the normal high beams also the passenger fog light is really dim but the drivers side is still bright... dont know if maybe i need a new headlight harness or maybe a relay is bad. its makin me mad!!
simple minds talk about other people.
average minds talk about events.
great minds discuss ideas
hmmmm this sux i really need to know what the heck this problem is
have you tried replacing all bulbs? I would do that first... start off with fresh bulbs then go from there to the relays/wire harnesses
i replaced all the bulbs, and then the one socket for the light that was giving me the problem, and i still have the problem. i guess ill try the relays next. thanks!
