Second O2 sensor - Maintenance and Repair Forum
Second O2 sensor
Wednesday, January 23, 2008 3:33 PM
Today, I installed a heated O2 sensor (sensor 1) inplace of the old faulty heated sensor. I also checked the spark plugs, changed the oil, and took the black box off (2200) the top to check the TB.
Tonight though, I through the code P0137. That has to do with low voltage on the rear O2 sensor. Since I didnt touch the rear O2 sensor, what might have caused this? Is the sensor just bad all of a sudden?
Re: Second O2 sensor
Wednesday, January 23, 2008 3:37 PM
the sensor could be bad or your cat could be clogged. I would try resetting the computer and see if it comes back up again. If it does, one of the two are suspect.
