today i put a starter in my car put it all back together now it wont start its turning over just not firingg
i also replace my starter and and it would turn over but not start and it turned out being a bad wire to the knock sensor.
can you hear the fuel pump kick in when the ignition is ON?
Did they test the old starter to make sure it was bad?
yea fuel pump turns on an the old starter was bad so im pretty confused
Change your fuel filter. That prevented me from starting once.
NCR-SCCA
turns out was the theft system had to be reset in the ecu
