Ok, odd question I know...
Anyone know if the N-body fuel tank will work in the J-body? They appear to be the same... same size, dimensions, etc.... just a couple of tiny details that are different (But I'm comparing a 00 cavalier tank with an 04 alero tank)
The only other thing I'm worried about is the pump... this came out of a 3400 V6 Alero... so it would be a higher-flowing pump, right? (Might not be a bad thing... might solve my lean issue
..j
WOO WOO. A chance to help Lenko.
Got a Gm Cert Tech behind me in the office. He says the fuel pressure spec on the 3400 pump is around 55 psi.
The 2.4 spec on pressure is 52.58, so the 3400 pump will be within the spec for the 2.4
Sorry the 52.58 should read 52-58 psi
only way to know is to try it
