I was wondering what the amperage is on the alternator on a 02 cavalier with a 2200 w/air and rear defrost. is it somewhere around 110 amp?
2009 Ford Mustang V6
i'm 99% sure it's 105 amps... i was checking that out yesterday at work
I wanna do the big 3 upgrade and I wanna match the fuse or circuit breaker to the amperage of the alternator. so I dont worry about shorting out anything.
105 sounds about right
MY 2003 SUNFIRE 15.63@87.86mph
~1QWKZ24
www.streetracing.org, 08/2001
just becareful bc your alternator is only supposed ot put out about half of the maxium amps so 105 divide by 2 = 52.5amps. if you push more then what its recommended to run is basically this...the biproduct of current flow is heat...you'll fry your alternator
~1QWKZ24
it will fry bc it wont have the nessary cool down time
~1QWKZ24
